16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> plumbing fixtures in foundation
40 Posts No Rating |
I am trying to create a foundation plan, and what I need to see in this plan is the exterior wall (with their respective footing), and plumbing fixtures. i don't have problems with the exterior walls, but with the plumbing fixtures. if I want to see the these, I would have to set the cut plan to 4' in the view properties, but I would see the interior walls too, and I don't want this,
Does anybody has a solution?
Thanks.
One solution is to make a view of only the plumbing fixtures that is the same scale as your foundation plan. Then drag that view of just the plumbing fixtures on to the same sheet as the foundation plan. Place the plumbing fixture view directly on top of hte foundation view, noting that Revit will give you the green alignment guides when the view is in the correct position.
You could also use worksets and/or plan regions but overlaying two views will get the job done quickly.
HTH
Tom
or just use a plan region...
Plumbing fixtures not displaying |
Mon, Feb 6, 2006 at 1:12:33 AM
Calculating Total Plumbing Fixtures needed |
Mon, Feb 3, 2014 at 9:39:13 AM
How to show plumbing fixtures on site plan? |
Fri, Jan 9, 2009 at 2:08:52 AM
Plumbing Schedule Totals |
Thu, Jan 30, 2014 at 1:05:02 PM
Revit MEP 2012 - Linked Cad Lines being trimmed by Revit Plumbing Fixtures |
Mon, Nov 7, 2011 at 12:54:25 PM
