Forums >> Revit Systems >> Technical Support >> fabmep to revit
Fri, May 8, 2015 at 9:51:35 AM | fabmep to revit
vinnygolfer
4.5 Stars: 4 Votes
hi all, i'm using Revit 2015 and my piping designers are using Autocad 2015 with FabMEP add on. i have a project that is requiring Revit deliverable. when i tried to import the .dwg file i got an error, "some acis objects could not be imported. to import them, use autocad to convert them into polymesh objects and re-import". i have tried to figure out how to do that in autocad, with no luck. i have exported the file as a .ifc, and then tried loading that into the Revit project with no luck. i have seen some posts on-line and none of them really give a way to do it, they just state that it's a problem. i have a week to get this done, but i'm trying to get out in front of this.
thank you
Try to learn at least one new thing every day
Fri, May 8, 2015 at 10:43:50 AM | fabmep to revit
See if this helps: http://www.revitcity.com/forums.php?action=viewthread&thread_id=17023
Fri, May 8, 2015 at 11:41:15 AM | fabmep to revit
vinnygolfer
4.5 Stars: 4 Votes
i have seen that before when i was searching. i don't know how to use that. i'm not a programmer, and have know idea where to even start with that list. i follow directions well, but don't know where to start with this.
Autocad FABmep 2013 Network License
Mon, Apr 29, 2013 at 5:49:28 PM
Specialist Fabrication company - deciding whether or not to adopt Revit?!
Mon, Feb 25, 2013 at 5:57:03 PM
Revit for Construction Documents [ 1 2 ]
Tue, Jan 24, 2012 at 10:57:38 AM
20
4D simulation in Revit? [ 1 2 ]
Mon, Jan 17, 2011 at 11:27:39 AM
18
I need to open a Revit 2011 file into the Revit 2009 ? Are there any way ? [ 1 2 ]
Thu, Jan 6, 2011 at 3:25:02 PM
18
Page generation time: 3.1146
