16 Users Online (14 Members):
Forums >> Community >> Newbies >> Window in wall section
For some reason my window is not sitting flush with my wall. I looked into the family and it there are no offset parameters in place and when i flex the model it functions perfectly however in this wall section the window is offset 0 3/8. I was thinking it might have something to do with the debth of the view but then i set it to 1/32" and nothing changed. Has anyone ran into this problem, do you know what is going on?
It looks like a family issue. Set the wall thickness in your family to the same as your model and see what happens.
I have flexed the wall and in the family view it looks fine. I figured it out. The wall section was set in the middle of the window on a curved wall surface. Is there a way to curve the window?
Or a way to get a section view to where the window isn't offset?
You can't curve a window. Revit is like the real world, can you bend glass? You have to built it curved if that is what you want.
Ok how do i get an accurate wall section from a curved wall where I want to show a window detail?
Use a detail component and make your section depth very shallow.
Window not cutting wall |
Mon, Jan 10, 2011 at 6:43:59 AM
Wall not showing in section |
Tue, Apr 23, 2013 at 4:19:40 PM
Demolished window automatic infill |
Fri, Mar 16, 2018 at 7:25:51 AM
Wall Reveal under Window Opening |
Thu, Jul 17, 2008 at 6:45:24 PM
wall disappears when placing window!!! |
Fri, Sep 14, 2012 at 6:43:39 AM
