Forums >> Revit Building >> Technical Support >> Revit 2015 showing drainage
Tue, May 5, 2015 at 4:23:21 AM | Revit 2015 showing drainage
PavPev
Not sure if this is the right section to ask this, please let me know if not!
I am trying to show drainage lines on my site plan in Revit 2015. I have positioned pipes and used a graphic override to show the centreline as a thick blue dash-dot and that works ok so far.
The problem I have is I want to show Foul Drainage and Surface Water Drainage on the same plan - I have used 2 different pipe types to draw them but they both look the same in plan view (due to the override). Is there a way to specify how the centreline looks dependant on Pipe type?
I would like to be able to hide the pipe outlines, without hiding the centreline of the  pipes too if possible, but at the moment this is a minor gripe
Any help is much appreciated, Thanks!
Pav
Wed, May 6, 2015 at 8:15:48 AM | Revit 2015 showing drainage
PavPev
The best solution I've come up with so far is to use the linework tool to apply a liner style to the pipework. This isn't ideal as it doesnt show the pipework through the floor construction (in plan) and also for some reason you cant apply a linetype to the centerline, even though you can change the centerline appearance in Visibility/Graphics?! So I ended up applying it to one side of my pipes, and turning the other side invisible so it just shows as one drainage line. It'll do for a 1:200 site plan but at 1:50 you can see its not centered up properly
Anyone know the proper way to do this?
Thanks
Pav
Site drainage
Thu, Jul 9, 2009 at 11:11:27 AM
drainage culverts
Sun, Apr 11, 2004 at 1:06:20 PM
Wall assembly layers not showing in fine detail - Revit 2015
Wed, Nov 19, 2014 at 12:16:01 PM
Beams not showing up in revit Architecture 2015
Tue, Sep 16, 2014 at 1:44:15 PM
Opening a 2015 drawing in Revit 2014
Tue, Jul 29, 2014 at 9:11:58 AM
Page generation time: 1.4514
