Forums >> Revit Systems >> Technical Support >> Pipe Joins
Mon, May 4, 2015 at 10:34:15 AM | Pipe Joins
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Revit 2015 Services has small pipes and small pipe joins OOTB. I am using Revit Services to do Civil Engineering. Large concrete underground pipes, manholes etc.
When you think about it, a small pipe and a join that connects it to another pipe is really the same as a large concrete pipe that joins another large concrete pipe at a manhole.
Is it possible to create such a pipe join such that say it allows 750mm diam pipe to join a 1800mm diam manhole along with other similarly sized pipes?
Thanks in advance.
Trim HSS Round pipe into another HSS Round pipe
Tue, Apr 3, 2012 at 4:39:45 AM
pipe dimensions
Wed, Dec 2, 2015 at 7:47:03 AM
Pipe Accessories and Pipe Type parameter
Tue, Dec 27, 2011 at 11:25:39 AM
Pipe Branch Takeoff/Gain
Fri, Feb 26, 2016 at 12:29:37 PM
Pipe Sizes
Thu, Jan 22, 2009 at 5:56:11 PM
Page generation time: 0.0456
