Forums >> Revit Systems >> Technical Support >> Printing in revit
Mon, May 4, 2015 at 8:21:49 AM | Printing in revit
sblanck71
So I have a designated place I pump PDf prints to when printing from Revit. I had a sub folder there that I deleted because I no longer needed it.  Now when I print and choose my destination folder revit creates this sub folder.  I have deleted the folder altogether and re created it and no dice. Any time I print PDF to this folder this sub folder regenerates.
Anyone have any ideas why?
Thanks
Mon, May 4, 2015 at 9:02:48 AM | Printing in revit
PDF creation depends on the driver you are using.   You did not tell us what that is.   Look there for the answer to your question.
Mon, May 4, 2015 at 9:14:30 AM | Printing in revit
sblanck71
Adobe is my driver
Mon, May 4, 2015 at 4:34:24 PM | Printing in revit
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
I’m not sure if that’s going to help, but try it. Windows Start -> Devices and Printers -> right click on Adobe PDF -> Printing Preferences -> Adobe PDF Settings tab -> in Adobe PDF Output Folder make sure it says Prompt for Adobe PDF filename or browse for the destination folder of your choice. Hope it helps.
Printing Query
Wed, May 23, 2012 at 7:54:08 AM
Printing Problems Revit 2012
Wed, May 16, 2012 at 7:31:01 AM
printing press
Wed, Dec 29, 2010 at 11:28:44 AM
Printing Lighting Plans in Revit MEP
Mon, Mar 14, 2011 at 9:20:35 AM
Fill Region set to Transparent but printing Opaque [ 1 2 ]
Sat, Jan 26, 2019 at 12:16:15 AM
18
Page generation time: 2.6599
