Forums >> Revit Building >> Technical Support >> Visibility in Family Editor
Thu, Apr 30, 2015 at 6:28:40 PM | Visibility in Family Editor
Dave375
Revit 2015
I have created a generic annotation family.  I have some lines in it that I have assigned a visiblity parameter to them so I can turn them on or off.  BUT I want them to be invisible by defaut, since they are rarely used.
It seems like I can only have them visible by default.
Fri, May 1, 2015 at 7:37:57 AM | Visibility in Family Editor
We create a sub-category for those kind of items that is normally set to off in our view templates.  In that way, we can also assign a color so you easily see these items when they are on.
Fri, May 1, 2015 at 11:50:25 AM | Visibility in Family Editor
Dave375
Thank you for the response.  I managed to get it to work by removing the family from the project completely, changing the lines in question to another object style and then reloading it into the project.
Sun, May 3, 2015 at 9:00:12 PM | Visibility in Family Editor
ronmalit
5 Stars: 3 Votes
just want to share. during family creation...
-create the YES/NO instance parameter first and dont assign it to any element
-disable the parameter (turn off) <---this is important. if you enable and assign it, it will be "visible by default"
-then  select lines and assign the visibility parameter.
those lines should be "disabled for default"
this applies to default values, default length etc etc
** dont be mad, i dont have much... i am homeless
adding mass in family editor or in place family creation
Thu, Nov 23, 2006 at 9:52:52 AM
Draw Order in Family Editor
Wed, Aug 28, 2013 at 3:07:31 PM
Family Editor: works... then doesn't!
Fri, Sep 2, 2005 at 5:23:05 PM
Revit Family Editor
Sat, Oct 1, 2011 at 12:46:05 AM
Family element Visibility Settings
Tue, Jun 11, 2013 at 4:08:30 AM
Page generation time: 1.5629
