12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Revit 2015 - Importing complex 3D DWG
35 Posts No Rating |
Does anyone have a good method for importing complex 3D dwg models into revit. We are working on a project with external consultants modeling manufacturing tanks & equipment in DWG. If we import these into our model it slows everything down to a unusable crawl. Ideally we need these tanks in the model & as they are contunually updated as the project progresses it is not worth us spending the time to model place holder families
Hopefully someone has a solution
The solution is first - try not to do this.
Second - Link - DON'T IMPORT and place the link on a workset that is normally not loaded. (Learn how to use a reduced load at startup.)
And finally - hopefully the people that created the CAD placed their over modeled elements on layers that you can turn off in the import. You don't need screws and bolts!
Help importing a dwg site plan into Revit 2015 |
Thu, Nov 3, 2016 at 3:56:15 PM
not to see imported dwg on every level (after importing dwg) |
Sun, Nov 26, 2006 at 11:13:58 PM
Dwg Importing |
Tue, Nov 28, 2006 at 10:12:09 AM
Help - Importing 3D Bentley to Revit (.dwg or .dgn to .rvt) |
Mon, Jun 2, 2014 at 7:53:20 AM
Importing DWG with clipped blocks |
Mon, Sep 17, 2012 at 12:00:44 PM
