Forums >> Revit Building >> Technical Support >> Revit 2015 - Underground Pipes Set Distance Below Topography
Wed, Apr 29, 2015 at 3:39:09 AM | Revit 2015 - Underground Pipes Set Distance Below Topography
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Hi all,
I am using Revit 2015 and need to show pipework at a set distance below the topography.
So as the topography rises or falls, so should the pipework. The pipework would need to "read" off the topography level directly above it.
Does anyone know if this can be done?
Thanks in advance
Beau
Wed, Apr 29, 2015 at 7:10:02 AM | Revit 2015 - Underground Pipes Set Distance Below Topography
I think you would have to do some sort of line based family using face based (site hosted) points that you initially place.
My question is does this really have to be modeled?  Why isn't it just a path?
Thu, Apr 30, 2015 at 8:04:23 AM | Revit 2015 - Underground Pipes Set Distance Below Topography
xtnuser
Oh boy. There certainly isn't any native method to achieve what you are asking. But there might be a work-around. If you watch the following vido, perhaps you can adapt some of the techniques, particularly the last one utilizing an entourage family.
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2013/revit-for-architects/ab3340#ooid=dpMHU2aTrCVtAvCORSwqbZ7VqnKzBLZB
Mon, May 4, 2015 at 1:04:32 AM | Revit 2015 - Underground Pipes Set Distance Below Topography
ronmalit
5 Stars: 3 Votes
hi xtnuser
i come here to read comments like yours
thanks for the link, i have learned a lot.
** dont be mad, i dont have much... i am homeless
underground
Fri, Sep 15, 2006 at 2:42:32 AM
Issues with Topography
Mon, Apr 18, 2005 at 1:22:56 AM
Trench family for underground utillites
Mon, Nov 10, 2014 at 1:50:19 PM
can't "reach" pipes (revit MEP)
Wed, Dec 21, 2011 at 6:24:35 PM
Duo pipes - Twin pipes for central heating
Wed, Jan 16, 2019 at 3:48:53 PM
Page generation time: 1.9839
