Forums >> General Discussion >> Revit Project Management >> cannot override graphics by category
Tue, Apr 28, 2015 at 10:36:11 AM | cannot override graphics by category
clickster
clickster Avatar
I am trying to override the surface pattern of a wall in an elevation view (no view template has been applied to the view). I followed these steps:
1. highlight element
2. right click
3. go to 'override graphics in view'
4. select 'by Category' ('by element' and 'by filter' are grayed out, but 'by category' is not)
After I do this, nothing happens. Has anyone had this problem, and know of a fix?
Thank you
Fill what is empty. Empty what is full. Scratch what itches.
Tue, Apr 28, 2015 at 1:07:10 PM | cannot override graphics by category
Try just doing this in VG since it is a category.
Tue, Apr 28, 2015 at 2:47:50 PM | cannot override graphics by category
clickster
clickster Avatar
that worked. thanks.
Thu, Jan 19, 2017 at 2:46:11 PM | cannot override graphics by category
archigrafix
5 Stars: 4 Votes
That object must have had subcategories. Override graphics in view by category and VG change the same database values / have the same effect.
To make all these adjustments directly in the selected objects you can try Graphic Studio that lets manipulate both the categories and element graphics. In this way you do not need to look after the right subcategories in the visuality graphic lists, you just select the object and adjust the graphics.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
OVERRIDE GRAPHICS OF A SINGLE ITEM IN A LIBNKED MODEL
Sun, May 31, 2020 at 11:35:18 AM
override graphics subcategories + phases
Fri, Sep 18, 2009 at 11:33:14 AM
ovverride graphics
Wed, May 21, 2008 at 6:10:26 PM
Visibilty of cut topography in section views
Tue, Mar 4, 2008 at 8:12:06 PM
Hatch in roof
Mon, Jun 25, 2007 at 11:05:15 PM
Page generation time: 1.3136
