18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Need the nonactive level symbol
0 Posts No Rating |
I have an RCP where the deck above is being exposed and would just be skim coated, but I want to note the height. I can't use the ceiling tag because there's no ceiling there to tag and I can't use spot elevation because it's a multi-story project. I should just be using a symbol, but I can't figure out how to upload that symbol to my project. It should be in the imperial library right? Any ideas? Thanks.
Multi-story has nothing to do with a spot elevation tag.
If you mean you don't want a real elevation then create your own target symbol if need be.
0 Posts No Rating |
Well, the spot elevation gives me like 200', but right that doesn't give me ceiling heights. I was hoping a symbol would be already created in the program since it's a standard symbol and I wanted to avoid creating one.
Spot elevation tag types can be created that are relative to the level. Why use a DUMB tag when it can be SMART?
0 Posts No Rating |
Because I need to tag a ceiling height and there isn't a ceiling there. It's exposed to the deck above.
Maybe I'm just being dense but I can spot elevate the bottom of my deck. I would assume that that is the elevation you want or do you want the bottom of the 'skim'coat? My PC deck is at 10' AFF and this is my RCP.
level symbol and field |
Fri, May 14, 2010 at 6:03:21 PM
new symbol from 2009 wont load as symbol in 2011 |
Wed, Jul 6, 2011 at 2:09:39 PM
Weld symbol editing |
Thu, Jan 6, 2011 at 9:50:16 PM
Symbol _level marker |
Mon, Oct 22, 2007 at 7:31:37 PM
2D nested annotation symbol doesn't show when family is sloped in 3D |
Tue, Aug 2, 2011 at 2:58:56 PM
