Forums >> Revit Building >> Technical Support >> creat double door w/ adjustable swing
Mon, Apr 27, 2015 at 11:16:49 AM | creat double door w/ adjustable swing
ledgewood33
I have created a single door with a parameter to allow for a change in the swing angle. so I went on to create a double door with a parameter to allow for a change in the swing angle. in the double door I am able to change the angle to any angle but 90 degrees. when I do so I get a prompt that says it make type and wants me to delete it. can anyone help me see where I went wrong. I am attaching the double door family.
Mon, Apr 27, 2015 at 11:44:33 AM | creat double door w/ adjustable swing
This is an old problem that you can read about in the similar threads below.
Mon, Apr 27, 2015 at 1:30:05 PM | create double door w/ adjustable swing
ledgewood33
I am going to try out some of those solutions that you pointed to.
what I dont understand is why the single door doesnt have the same problem as the double door?
Help help diagnosing double door with adjustable swings
Thu, Jun 11, 2015 at 3:35:52 PM
adjustable double door
Tue, Mar 27, 2007 at 10:23:28 AM
Plan adjustable door swing issue
Mon, Oct 1, 2012 at 9:13:26 PM
Nested Door Family w/ Adjustable 3D Swing Angle
Tue, Jul 31, 2007 at 5:34:20 PM
door with jambs and adj swing
Thu, Feb 12, 2009 at 8:46:01 AM
Page generation time: 2.2869
