21 Users Online (19 Members):
Forums >> Revit Systems >> Technical Support >> 3d model text in grid bubble
hi all. i'm using Revit 2015, and i have a question. how can i make a grid bubble have 3d text that can be rotated and show up in a 3d view?
Try to learn at least one new thing every day |
Grids do not show in 3D.
2 Posts No Rating |
As WWHub said, standard Revit grids are not a 3D element. BUT you can make a family that you manually place (line based) that can show up in 3D. Depends on how you're going to use it, but you can read this old blog post for starters:
http://cad-vs-bim.blogspot.com/2013/10/3d-grids-in-revit-oldie-but-goodie-done.html
This is horizontal, not vertical, but gives you a starting point! The family download is pretty clean too so you can use it right away.
Thank HKicsak,
this is a great work around to use for my spool drawing 3d maps. i will definately be using it. the only thing that i wish(but not needed is that the numbers could be standing up. other than that, it is perfect.
thank you, thank you, thank you!!!
Column grid text too wide to fit in bubble |
Thu, Jul 1, 2010 at 8:32:06 AM
Grid Lines - Instance based text in grid line family |
Mon, Jul 23, 2018 at 2:17:14 PM
Grid Bubble formatting between projects |
Sun, Oct 26, 2014 at 8:33:04 AM
Column Grid Text |
Tue, Dec 11, 2007 at 9:33:36 AM
Different Grid Bubble for different scale views? |
Thu, Dec 12, 2013 at 5:42:13 AM
