Forums >> Revit Building >> Technical Support >> [Help] Make a wall connect close to the top of the roof
Thu, Apr 23, 2015 at 9:57:21 AM | [Help] Make a wall connect close to the top of the roof
Mrmult
Hi fellow Reviters!I would like to find out how you guys would connect a wall to a roof, so that the wall connects close to the TOP of the roof.Right now the wall attaches to the bottom, you never build like that, do you?Hope you understand what I try to achieve. I've added  two pictures showing the project.The red area in pic #2 shows how I would like the wall to almost reach the top of the roof instead of the bottom.(Not the whole wall, part of it).Thanks in advance/M.
Thu, Apr 23, 2015 at 11:22:09 AM | [Help] Make a wall connect close to the top of the roof
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
If that is what you want create 2 different roofs, 1 for the structure and 1 for what you want your wall to go up to
Thu, Apr 23, 2015 at 11:44:37 AM | teafoe5
Mrmult
Quoting teafoe5 from 2015-04-23 11:22:09
"If that is what you want create 2 different roofs, 1 for the structure and 1 for what you want your wall to go up to"
Yeah, I want the wall to follow the roof, not attach to the bottom. So that the outer layer is connecting to the top instead of the bottom. Should I make separate walls and use a void, or what's the easiest way?(I also want the wall to follow the slopes of the roofs)  Hope the included picture shows what I mean (section).
Edited on: Thu, Apr 23, 2015 at 11:46:23 AM
Edited on: Thu, Apr 23, 2015 at 11:46:53 AM
Thu, Apr 23, 2015 at 7:29:13 PM | [Help] Make a wall connect close to the top of the roof
mansell5
3.5 Stars: 4 Votes
try using "edit profile" of walls in elevation view, that way you can follow roof line.
Thu, Apr 23, 2015 at 8:39:41 PM | [Help] Make a wall connect close to the top of the roof
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Yep, do not attach wall to the roof, edit wall profile instead – see picture.
Fri, Apr 24, 2015 at 12:45:03 AM | [Help] Make a wall connect close to the top of the roof
Mrmult
Thanks a bunch guys, will try it out! I'll write if something comes up Smile
How to make the top of the wall not horizontal?
Sun, Jan 23, 2011 at 7:17:41 AM
Roof by Face and Wall by face tools
Tue, Jan 28, 2014 at 6:31:03 AM
Walls will not connect to ceiling or roof
Mon, Mar 2, 2015 at 8:25:47 AM
curtain wall cuts when close to floor line
Thu, Aug 27, 2015 at 4:48:48 PM
Roof Help Back Slope, Top Chord Extension
Sat, Jan 29, 2011 at 5:09:43 AM
Page generation time: 2.6995
