14 Users Online (12 Members):
Forums >> General Discussion >> Revit Project Management >> View dependent material surface patterns
Is there a way to have a given material display different surface patterns in different views? I am creating elevation diagrams, in which I want to assign a hatch pattern to my solid materials. I assigned a hatched surface pattern to the material, but this seems to assign the surface pattern globally, and it shows up on all my other elevations (not just the diagrams). Any help would be appreciated.
Fill what is empty. Empty what is full. Scratch what itches. |
Don't actually change the material just override the pattern in the view.
If I use visibility override by category, then the other objects in the category would be affected (which I don't want). Over-riding by element would be very time consuming. I was hoping there would be a way to assign a surface pattern to the material and then somehow use a view setting to change the material's surface pattern, only in that given view.
"Over-riding by element would be very time consuming" What are you trying to override? Just click on it, right click and select all instances.
ok thanks
materail surface patterns |
Fri, Jun 13, 2008 at 8:06:11 AM
Existing Phase Surface Patterns visibility |
Tue, Nov 14, 2006 at 6:37:24 PM
Missing surface patterns in 3D [ 1 2 ] |
Fri, Apr 10, 2009 at 12:46:53 PM
16
No Surface Patterns in Perspective |
Thu, Feb 1, 2007 at 4:55:53 PM
Dependent views not the same as Parent view... |
Fri, Jun 16, 2017 at 11:02:18 AM
