Forums >> Revit Building >> Technical Support >> Revit Hatch Patterns Different in Thin Lines Mode
Tue, Apr 21, 2015 at 10:23:59 AM | Revit Hatch Patterns Different in Thin Lines Mode
archiphotovt
I am putting this here in case anyone else runs into this issue.
I created/edited several custom hatch patterns for rated walls. I then loaded them all into the template and into a project. Everything seemed to be working perfectly. However, later I noticed that one of the patterns wasn't showing correctly. Rather than being a series of 45 degree slanted lines, it was showing as a solid fill. Strangely enough, the issue went away when in thin lines mode. So thin lines = correct pattern, and normal mode = incorrect pattern. I had no clue what the deal was.
I tried several things to no avail. Then I decided to check the other patterns and look for any discrepancy. The only one I found was the alignment of the pattern. All the patterns that worked correctly were aligned with element. The incorrect one was align to view. Once I changed this setting, all was working well again. Align to element is what I wanted anyway, not sure how I missed one of them.
Hopefully this helps someone avoid an hour or two of frustration.
Autodesk Revit 2014 on Windows 7 Professional
Edited on: Tue, Apr 21, 2015 at 10:26:25 AM
Gray Hatch Lines
Mon, Sep 2, 2013 at 8:01:02 PM
Custom Hatch Patterns
Thu, Dec 23, 2004 at 3:00:32 PM
imported acad hatch patterns
Sun, Nov 25, 2007 at 6:39:02 PM
Hiding Hatch Patterns [ 1 2 ]
Sat, Aug 29, 2009 at 8:12:25 AM
15
FLOOR HATCH SHOWS THROUGH 3D COMPONENTS
Thu, Oct 19, 2017 at 1:41:24 PM
11
Page generation time: 2.4646
