Forums >> Revit Building >> Technical Support >> Receiving "Can't keep elements joined" message when joining 3 family elements
Tue, Apr 21, 2015 at 10:20:51 AM | Receiving "Can't keep elements joined" message when joining 3 family elements
ElojMelenova
I'm trying to join 2 polygon extrusions with a revolve, and keep getting the warning, "Can't keep elements joined."
Using Revit Architecture 2015 student version.
Here's the file attachment
Tue, Apr 21, 2015 at 11:26:44 AM | Receiving "Can't keep elements joined" message when joining 3 family elements
You actually have 3 pentagon extrusions there, not two.  If yo go to the plan view and select the revolve, you will see the third hidden pentagon.  That, however, is not your problem.  Revit just plain doesn't like what you are doing.
From plan view, I would create the pentagons in a different family and bring them in.  Then I would use voids to cut the revolve and not join the geometry.   (If you have the petagons here when you create the void, the void will cut them as well and you don't want that.)
Endless "Cannot Keep Elements Joined" Error
Tue, May 20, 2014 at 1:29:33 PM
tagging by "family name" and "family type"
Mon, Jun 1, 2009 at 8:54:54 PM
Project Sharing Warning Message exceeded "Number of People"
Thu, Dec 3, 2015 at 7:01:51 AM
Elements can't be copied because they will lose their References.
Wed, May 13, 2015 at 4:43:24 PM
Pickup data tables of families of "elements of detail"
Thu, Oct 4, 2012 at 7:14:55 AM
Page generation time: 2.4728
