11 Users Online (10 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> beam system
Mon, Apr 20, 2015 at 6:58:34 PM | beam system
Dave375
These beam systems are killin me, though not any worse than most things on Revit that you've never done before.
So I have a beam and a wall and I want to use them as supports for a beam system.  Somehow I cannot choose them as supports and so the beam system is at the level associated with the plan view and it's flat.  I've been stuck on this for a while now and I would almost rather just place the beams manually, but I know this has to work.
Wed, Apr 22, 2015 at 10:35:51 PM | beam system
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Make sure your walls are structural and check 3D option in beam system properties.
Beam system height VS. Beam height error
Fri, Jan 22, 2016 at 4:31:20 PM
Adding a beam system issue
Sun, Jun 15, 2014 at 2:58:10 PM
Beam System Tag
Fri, Aug 14, 2009 at 3:09:33 AM
Schdule of Beam System
Tue, Jan 4, 2011 at 5:45:12 AM
beam system
Thu, Oct 15, 2015 at 7:32:17 AM
Page generation time: 0.2296
