11 Users Online (10 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> how to remove a "Work Plane" 2008 REVISION 1 STRUCTURE
Mon, Apr 20, 2015 at 3:23:01 PM | how to remove a "Work Plane" 2008 REVISION 1 STRUCTURE
billbe
I am learning this software (maybe). I added a Work Plane to the underside of a sloped "shed" roof to, I thought, be able to generate a view of the framing of this roof. Didn't work out as the grid of this work plane is not parallel to the column lines plus it seem impossible to be able to add framing on the slope of the roof.  Can  this work plane be removed?
Mon, Apr 20, 2015 at 3:25:40 PM | how to remove a "Work Plane" 2008 REVISION 1 STRUCTURE
Why are you using 2008?   UPGRADE!
If you are just using a free version, you can still do that - just download it.  2016 is now out.
Fri, Apr 24, 2015 at 4:08:14 PM | how to remove a "Work Plane" 2008 REVISION 1 STRUCTURE
billbe
I use 2008 because it's paid for. The "Free" new version is only free so someone can try it out: it disappears after a while.
So I wonder if someone who has used Structure for a long time can give me a answer/
Thanks for your help
CAD software limitation with Revit Structure 2008
Mon, Dec 3, 2007 at 10:22:16 AM
Opening 2008 file in 2009 causes "Unrecoverable error" crash
Tue, Jul 28, 2009 at 1:36:33 AM
Calculated field on sheet to state whether "numeric" or "Alphabetic" no. used
Tue, Jul 10, 2012 at 7:07:05 AM
ABOUT SET UP WORK PLANE
Thu, Aug 5, 2010 at 9:30:56 AM
The definition of "Front" in 3D View and rotating a complete structure
Thu, Jun 30, 2016 at 7:53:41 AM
Page generation time: 1.6129
