Forums >> Revit Building >> Technical Support >> Stair Cut Line : Double Line
Mon, Apr 20, 2015 at 1:07:42 PM | Stair Cut Line : Double Line
kottwitz
Hi, I am playing around with stair representations, as my boss dislikes how revit displays stairs.
Ive been adjusting with in the VG, hiding given lines, above supports I remember within the type properties of Stairs, under graphics there is an option for a double cut line/break line... Giving some sepparation where the stair is being cut, this option is missing from mine or possible It has been moved... See image below... Thanks
Im not sure and hopfully its not due to the type of stair, or VG ive adjusted...
Thanks in Advance...
Mon, Apr 20, 2015 at 2:01:06 PM | Stair Cut Line : Double Line
What Revit????
Stair by sketch and by component are different.   By component has the double line possibility.
Mon, Apr 20, 2015 at 2:09:23 PM | Stair Cut Line : Double Line
kottwitz
Sorry, 2015...
This is by sketch, is there a work around?
Thank you for the reply.
Mon, May 18, 2015 at 3:19:08 AM | Stair Cut Line : Double Line
voduong
When i use revit 2015 .I have confused
why is arrow head  covered by cut mark in stair by component ?
Revit 2014 - Stairs double cut line in plan
Tue, Sep 9, 2014 at 11:14:46 AM
Can't modify (or switch) stair cut line/break line
Wed, May 11, 2016 at 10:58:08 AM
Stair Cut Line
Tue, May 29, 2007 at 4:03:27 PM
Stair above cut line question
Tue, May 6, 2008 at 10:50:29 AM
Stair break line (Revit 2008)
Mon, May 12, 2008 at 7:43:21 AM
Page generation time: 4.9548
