Forums >> Revit Building >> Technical Support >> HELP, just some quick questions
Wed, Mar 22, 2006 at 7:05:08 AM | HELP, just some quick questions
Skeight651
In relation to building exterior walls from different materials. How can you change the material midway up the wall.. To go from stone, to lets say, vinyl siding. How do you dimension angles? angular wall movement. And lastly, does anyone have any tips about winding staircases or something close
Wed, Mar 22, 2006 at 2:56:42 PM | RE: HELP, just some quick questions
arccodex1
3 Stars: 1 Votes
You can change the material midway up the wall by using a Stacked Wall. You have to create the two wall types seperately first. There should be a default Stacked Wall among your other walls in the drop-down list. Just duplicate and edit this one. To dimension Angles select the dimension tool. On the Options Bar there are a number of dimension types you can use. One of them is Angular.
Print Icon on Quick Access Toolbar
Wed, Oct 29, 2014 at 6:27:05 AM
G'Day and a quick intro
Thu, Jul 28, 2011 at 6:47:02 PM
Quick rendering
Sat, Nov 26, 2016 at 10:37:42 AM
Multiline text below dimension
Tue, May 10, 2011 at 9:32:42 AM
Linetypes and Phases
Wed, Nov 30, 2005 at 11:07:15 PM
Page generation time: 1.7234
