Forums >> Revit Systems >> Technical Support >> Creating Turning Veins
Mon, Apr 20, 2015 at 10:29:21 AM | Creating Turning Veins
bpenalba
Hello,
I am having trouble creating turning viens for a rectangular elbow. I have tried editing the family and just adding annotation lines but after i load it into my project the viens look sloppy. Or when i change the Width and Height of the elbow in the project the viens dont adapt to the size. Instead the lines do connect to the corners or the ticks look sloppy.
Would anyone have a step-by-step guide on how to add turning viens when editing a family for a retangular elbow?
I dont mind if the guide is even long, I just want to get the job done correctly.
Thanks!
Mon, Apr 20, 2015 at 11:22:44 AM | Creating Turning Veins
This would be created just like a louver.   The old 2010 "families guide' that can be downloaded from the autodesk site shows how to nest a louver type family into another family.
Mon, Apr 20, 2015 at 11:32:36 AM | Creating Turning Veins
Gyvven
5 Stars: 2 Votes
Is there a reason you're creating your own instead of using the out of the box version? The OOTB Rectangular Elbow Mitered - Single Thickness Vanes.rfa is a decent example to follow if you're trying to make something custom. It's pretty minimal in the number of parameters needed to make it flex properly, and uses an array of a nested family with model lines, and some simple formulas. Lots of good stuff to learn from in this family. I use this as our default elbow with an instance parameter to either show vanes or not.
Tue, Apr 21, 2015 at 6:29:38 PM | Creating Turning Veins
bpenalba
Hello,
I just didnt know about how to put turning viens on the elbows and i didnt know there was already a default existing family. Thank you
Vehicle Turning Circles can find any
Thu, Oct 9, 2008 at 6:51:52 AM
turning on/off nested families in host family in different views in project.
Fri, Aug 7, 2009 at 11:11:32 AM
Turning off one view title tag without turning them all off
Thu, Feb 22, 2007 at 6:27:42 AM
Turning off certain elements in Visiblity Graphics (VG)
Sat, Sep 9, 2006 at 6:12:07 AM
Turning Vanes in Mitered Elbows
Fri, May 30, 2008 at 2:42:04 PM
Page generation time: 0.3462
