Forums >> Revit Systems >> Technical Support >> Invert Elevation Vs. Spot Elevation
Fri, Apr 17, 2015 at 3:42:34 PM | Invert Elevation Vs. Spot Elevation
Pikachu123
I incorporated the Invert elevation apart of my Custom Pipe Tag i created, and when i used the spot elevation command. There is a 1/2" bust between my tag and the apot elevation. What is the difference between the "Invert Elevation" parameter available in Labels, and Spot elevation? Where is that 1/2" bust comming from. I checked the tolerances and they are both the same (round to the nearest 1/8"), and the pipe thickness of the pipe i am referencing isn't an 1/2". Does anyone out there know what causes this?
Fri, Apr 17, 2015 at 3:44:04 PM | Invert Elevation Vs. Spot Elevation
Pikachu123
Snip attached...
Fri, Apr 17, 2015 at 4:00:05 PM | Invert Elevation Vs. Spot Elevation
Pikachu123
Oh by the by, the spot elevation is referencing Bottom of Pipe.***
Mon, Apr 20, 2015 at 1:07:43 PM | Invert Elevation Vs. Spot Elevation
Gyvven
5 Stars: 2 Votes
The Invert Elevation is bottom of the Inside Dia., whereas the Spot Elevation is the bottom of the Outside Dia. The difference is the thickness of the pipe wall (if you don't round).
Mon, Apr 20, 2015 at 2:09:11 PM | Invert Elevation Vs. Spot Elevation
Pikachu123
Thats what i was thinking, but i just wanted to make sure. Greatly appreciated for the clearing of the fog. I can see clearly now. Thanks again kind sir.
invert elevation tag
Thu, Aug 27, 2009 at 6:26:27 PM
Spot Elevation vs. Level elevation
Tue, Aug 19, 2025 at 1:06:15 AM
Invert elevation tag for plumbing fixtures
Wed, Aug 17, 2011 at 11:21:32 PM
Invert Elevation Tag
Wed, Jul 23, 2008 at 11:24:53 AM
Spot Elevation without Target
Fri, Mar 20, 2009 at 4:57:55 PM
Page generation time: 0.2375
