16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> elevation start point
63 Posts No Rating |
can anyone tell me if it is possible to step the elevation start point that you see in the floor plan so that it follows the shape of the building. The terrain on a job Im doing at the moment undulates & if the elevation starting line is straight it doesnt show the ground level right at the wall face, it shows the ground level where the elevation line is.
do I make sense?
i guess I mean similar to a section line that steps in & out at the locations that you want the model cut.
41 Posts No Rating |
Good question, i would like to know the same.
I think everyone would like to know how to do this, its a real pain!
One workaround is to forget using the elevation tools and draw your elevations as sections (which can be stepped) and adjust the labels accordingly.
If anyone knows how do this using elevations, tell us - everyone wants to know!
I take it that this is just not possible. (i cant beleive it!) It means almost a total redraw of 2 of my elevations from the ground level to floor level- pain in the a__
How does everyone else overcome this shortcomming?
cheers
28 Posts No Rating |
Well, one thing you could do is draw in a filled region (with an earth pattern) in the shape you are needing to see, then turn of your topography in that view. I know it's not a great solution, but works when I need it to.
Vanessa
Yes definitely not possible.
two workarounds suggested above are the best methods of approach.
How to retrieve start point and end point of Elbow |
Wed, Jul 6, 2011 at 3:47:48 AM
Topography Elevation from Project Base and Survey Point is Incorrect |
Thu, Jan 29, 2015 at 10:32:24 PM
Toposurface Elevation Base Point |
Thu, Apr 28, 2016 at 4:35:51 PM
Toposurface is drawn at the wrong elevation relative to levels |
Fri, Aug 4, 2017 at 12:09:48 PM
Display both Project Base Point and Survey Point on Elevation Datum. |
Fri, Aug 29, 2014 at 5:57:41 PM
