13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Schedule Grid is not showing up property
1 Posts No Rating |
I am running bootcamp, its seems like the GUI scaling is off for the grid. Any easy fix?
Thanks
I have the same bootcamp setup and have the same problem.
The schedule will display properly in a sheet.
But if you need to edit it outside of a sheet, you will need to increase the size of each of your columns and / or adjust your text size.
Column grid not showing up |
Thu, Jan 24, 2008 at 11:49:48 AM
Property line tables on sheet |
Tue, Mar 14, 2017 at 1:29:57 PM
ROUNDING VALUE ON PROPERTY LINE BEARING |
Fri, Apr 8, 2016 at 1:13:37 PM
Property Lines on Toposurface |
Mon, Jul 9, 2007 at 10:22:49 AM
column grid visibility |
Wed, Nov 15, 2006 at 3:43:13 PM
