Forums >> Revit Structure >> Technical Support >> Shaft!!
Mon, Apr 13, 2015 at 2:52:13 AM | Shaft!!
amrghanem
after creating a raft foundation I wanted to make a trensh through a specific part in the foundation so I used the shaft option. the problem is that the shaft cut in the foundation with its whole hieght although I set the shaft with the trensh dimensions needed (for ex: trensh with hieght 0.5m, foundation with hieght 2m) but still cut the foundation at 2m hieght. Any Ideas..???
Mon, Apr 13, 2015 at 6:53:32 AM | Shaft!!
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Don't use a shaft.  Use an in-place void to cut your floor.
Mon, Apr 13, 2015 at 8:51:04 AM | Shaft!!
amrghanem
Thanks for help... it benefits me alot
shaft cutting beams
Tue, Jun 2, 2009 at 7:47:18 AM
A Floor That Can't Be Penetrated by Shaft Opening
Thu, Feb 20, 2014 at 2:30:48 PM
Shaft Problem
Thu, Jul 12, 2012 at 5:20:52 PM
Shaft Visibillity
Wed, Jun 1, 2011 at 10:47:37 AM
Visible shaft in 3D view
Tue, Aug 10, 2010 at 8:02:51 AM
Page generation time: 0.4663
