16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Best way to show outline of building under roof on site plan
Hey guys I am trying to show the outline of the building only. I have tried using show hidden lines but it shows both inside and outside of the wall and windows.
I am currently using the linework tool which is a bit slow.
Is there a better way? Thanks.
Revit 2018........ |
The linework tool will not give you the outline ONLY as you asked but perhaps you mean you only want to change the outline of the building. If that is the case, click on the visual style button at the bottom, then the graphic display options, view must be hidden line, then under silhouettes, pick the line you want to use and apply it. NOTE: This will outline some elements you may not want outlined. For those few elements, you can now use the linework tool to change these back.
Thanks again WW Ill give it a shot. Much appreciated.
BUILDING OUTLINE |
Sun, Feb 25, 2007 at 8:04:29 PM
RAC2008 - Building footprint on Roof Plan |
Wed, Aug 15, 2007 at 11:49:47 AM
Is it possible to show ROOF OUTLINE on FLOOR PLAN? |
Fri, Jan 23, 2004 at 11:21:47 PM
Roof Plan not Showing in Site Plan |
Wed, Jul 12, 2017 at 12:03:32 PM
11
HOW TO SHOW SUBREGION OUTLINE ON FLOOR PLAN |
Mon, Jul 11, 2011 at 7:32:06 PM
