16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> structural columns
i am dropping some W-sections and some HSS columns into my 1 story model. i cannot attach the columns to the generic roof that we have. the roof is sloping, and other than cutting a quick section at each column location to determine height to the roof, is there a quick way to get the columns at the appropriate height?
2 Posts No Rating |
Visually, you can create a reference plane locked to the top of the roof (or offset 1" above). You can then use this reference plane to cut each and every column.
That's the only solution I've found so far.
Looks like version 9 could possible have a fix for this...
structural wall VS structural columns |
Tue, Apr 26, 2016 at 3:49:39 PM
Structural columns |
Mon, Jan 16, 2012 at 8:37:32 AM
Structural Columns not cutting walls |
Mon, Jan 4, 2016 at 4:13:25 PM
Beams won't intersect or close-up to Structural Columns. Solution ? |
Tue, Oct 18, 2016 at 2:01:11 PM
Structural graphical columns schedules |
Mon, Apr 25, 2016 at 3:19:18 PM
