Forums >> Workflow & Implementation >> Training >> decreasing the volum of a family
Thu, Apr 9, 2015 at 8:54:20 AM | decreasing the volum of a family
samanehjav
hi
i have made a family which has a lot of detailed options and the result is a heavy family which cannot be inserted in my revit file . is there any easy way to decrease the familes volum ?
Thu, Apr 9, 2015 at 8:59:09 AM | decreasing the volum of a family
The only way I know is to edit the family.  'All in One' families are rarely a good idea.
Thu, Apr 9, 2015 at 9:42:06 AM | decreasing the volum of a family
samanehjav
would u plz explain more? i couldn't understand your meaning compeletly
Thu, Apr 9, 2015 at 9:44:22 AM | decreasing the volum of a family
You say "...a family which has a lot of detailed options..." .  To me, that means you have a lot of things that maybe you don't need.  Perhaps they should be detail components added at the project level.
Thu, Apr 9, 2015 at 9:58:28 AM | decreasing the volum of a family
samanehjav
i am trying to creat a grating floor which has 210 centimetr width and 2635 centimetr length with 5 centimetr spare between bars . so there are alot of bars and a heavy family
Thu, Apr 9, 2015 at 10:37:12 AM | decreasing the volum of a family
And now we hear the rest of the story......
Gratings should never be modeled!  Use a material for rendered views and detail elements for detail views.  The material can have a hatch pattern that will read correctly in plan.
Thu, Apr 9, 2015 at 12:06:24 PM | decreasing the volum of a family
samanehjav
thank you very much
create a custom fill pattern
Sat, Jun 26, 2021 at 6:04:50 AM
Adding room, spaces to half sphere...Revit 2013
Wed, Oct 10, 2012 at 8:40:02 AM
Cut Profile Line Weights (Revit Glitch?)
Mon, Aug 21, 2017 at 8:20:35 AM
Wall assembly demolish schedule
Fri, Oct 24, 2014 at 8:23:56 AM
The pattern with the values specified is too dense/too large
Fri, Aug 3, 2012 at 10:46:38 AM
Page generation time: 0.6405
