Forums >> Revit Building >> Technical Support >> changing material on a wall
Wed, Apr 8, 2015 at 4:24:17 PM | changing material on a wall
ENMelanson
so i have a wall that extends past a roof, so it's partially interior and exterior, is there a way to set a boundry at the bottom of the ceiling for the interior finish, and then have it apply the exterior cladding to the remainder?
this is a screen-shot of the wall in question http://puu.sh/h6y4e/54c56439d8.jpg
thanks
Thu, Apr 9, 2015 at 7:02:47 AM | changing material on a wall
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You would need to split your walls at that location and you could use a stacked wall or simply one wall up to the ceiling and another beyond that.  If you don't need to get really technical then you could just use one wall type and use the split face tool and paint it.
Thu, Apr 9, 2015 at 7:09:22 AM | changing material on a wall
ENMelanson
Thanks, I'll try that.
Thu, Apr 9, 2015 at 8:27:41 AM | changing material on a wall
Teafoe's answer will work.  The one shown here in your help may also work.
Changing material on a Curtain Wall
Tue, Apr 21, 2009 at 6:30:19 AM
Changing wall materials
Tue, Aug 31, 2010 at 8:13:34 AM
11
Phasing and changing material finishes
Wed, Apr 30, 2008 at 11:03:55 AM
Similar wall types with different finish colors...
Thu, Apr 17, 2014 at 1:00:57 PM
Nobody's answering this one!
Thu, Jan 26, 2012 at 1:01:03 PM
Page generation time: 0.6508
