Forums >> Revit Building >> Technical Support >> Showing Shafts in 3D as having "walls"
Thu, Apr 2, 2015 at 10:47:57 AM | Showing Shafts in 3D as having "walls"
revitdeco
I have an existing building that we are demolishing.  The contractor wants us to show a "shaft" through multiple floors, where we cut out the floors, and are hoisting and rigging equipment.  Is it possible to show a shaft's "walls" in 3D?  I can't find anything in VG that helps, or through any filters.
Thanks
Thu, Apr 2, 2015 at 10:56:37 AM | Showing Shafts in 3D as having "walls"
Shafts do not have walls - they are openings.  You can place 'shaft' walls that span multiple levels inside that opening.  Just use a wall that is defined as your shaft wall.  It could be thin and glass like property with the walls in a workset that is normally off.....
Edited on: Thu, Apr 2, 2015 at 1:06:12 PM
Level 1 room boundries showing up in foundation level
Fri, Feb 15, 2008 at 9:31:36 AM
{3D} view set to "Shading with Edges" looks like "Wireframe" with color...
Wed, Aug 12, 2009 at 7:05:45 AM
11
Families that are "behind" cut showing up in interior elevations.
Wed, Jan 23, 2008 at 10:50:16 AM
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:49 PM
Basement Wall Function: "Foundation" or "Exterior"?
Fri, Mar 26, 2010 at 12:27:21 PM
Page generation time: 3.8894
