Forums >> Revit Building >> Tips & Tricks >> Door Swing Angles
Tue, Mar 21, 2006 at 8:31:54 AM | Door Swing Angles
RobertHaight
I assume this is a simple question, but I haven't found the answer. How does one adjust the angle of opening for doors in plan? i.e. so the door shows as only open 45 degrees, or all the way around or whatever. Thanks
Tue, Mar 21, 2006 at 8:46:48 AM | RE: Door Swing Angles
JAIMERIOSJR
Hola: The way I have accomplished this task is modifying the lines on the plan view at the door family. The modification displays the door at a 45 degree angle. Once modified, I saved it adding 45 to the door family name. I hope this works.
Tue, Mar 21, 2006 at 9:51:34 AM | RE: Door Swing Angles
rodells
There is an 'adjustable door' family on the RevitCity downloadable file libraries. It has parameters that let you set swing angles and other door properties - you can use this instead of a huge collection of doors - it's pretty cool!
Tue, Mar 21, 2006 at 10:02:16 AM | RE: Door Swing Angles
RobertHaight
Thanks. I knew it was possible, and that this forum was quicker than re-inventing the wheel again.
Tue, Mar 21, 2006 at 12:50:54 PM | RE: Door Swing Angles
glorybound
Here is a simple tutorial
Thu, Apr 17, 2008 at 5:09:25 PM | Door Swing Angles
AbelGoddard
AbelGoddard Avatar
Not so much a 'simple' tutorial. Several things not explained in it for the novice.
Helping you Be Able to be the person you want to be!
Sign up for my free newsletter, Being Able, at http://www.AbelGoddard.com
Thu, Apr 17, 2008 at 7:03:51 PM | Door Swing Angles
coreed
coreed Avatar
4 Stars: 16 Votes
maybe this give a little more info
http://knowingwhatyoudontknow.blogspot.com/2008/01/adjusting-door-swings.html
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Jul 18, 2011 at 5:32:22 AM | Door Swing Angles
Flaviosyd
In this page there's a downloadable door with swing parameter.
http://cad-passion.webs.com/index.htm
Door swing with different angles in floor plans
Mon, Aug 29, 2011 at 1:32:06 PM
11
Door Swing Question
Mon, Oct 22, 2012 at 3:51:32 PM
12
REVIT 2014: Door Elevations - swing lines are shown backwards? [ 1 2 ]
Tue, May 12, 2020 at 2:41:52 PM
16
Revit 2015 Curtain Wall-Offset Pivot-Single Door
Thu, Aug 6, 2015 at 11:32:27 AM
Door Swing
Thu, May 18, 2006 at 4:20:39 AM
Page generation time: 0.1531
