Forums >> General Discussion >> Revit Project Management >> VG Filtering Walls by Different Base Contraints
Tue, Mar 31, 2015 at 2:31:06 PM | VG Filtering Walls by Different Base Contraints
revitdeco
Hello,
 I am trying to create a rendering of a very complex building with lots of levels.  I'm trying to have the walls on the higher levels be more transparent, and gradually become less transparent as it gets down the the bottom level.
I figured out how to do this with floors, because they have a "Filer by:" levels option, which surprisingly, walls do not.
Any help is much appreciated.
Thanks,
Rick
Wed, Apr 1, 2015 at 7:02:08 AM | VG Filtering Walls by Different Base Contraints
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Add a project parameter called Floor Level or whatever you would like under the wall category and then it will show up in filters.  You would have to manually input this information but that is the only way I can think of to do this.
Wed, Apr 1, 2015 at 8:16:33 AM | VG Filtering Walls by Different Base Contraints
revitdeco
Thanks for the response.
And that's the answer I was afraid of.  1,000+ walls, this will take a while.
Just doens't make sense why a built in parameter wouldn't be in the filter.
OH well.
Wed, Apr 1, 2015 at 8:24:00 AM | VG Filtering Walls by Different Base Contraints
This is one of those places where Dynamo would probably work.   Read the walls hosting level and copy that to your parameter.
Iv'e never used it yet.
Wed, Apr 1, 2015 at 8:25:05 AM | VG Filtering Walls by Different Base Contraints
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
It might not take that long, you don't need to physicall select each individual wall.  Just go to each floor plan and click on 1 wall type, right click and select all instances in view and it will only select those wall types on that level.  It will still be a process but a bit easier one.
Wed, Apr 1, 2015 at 8:30:14 AM | VG Filtering Walls by Different Base Contraints
revitdeco
Yah good point.
Work smarter, not harder.
Wed, Apr 1, 2015 at 8:32:25 AM | VG Filtering Walls by Different Base Contraints
revitdeco
So is there a way to have my parameter be linked to my current levels?
For example, I want the levels that I have created, to be the only options for that parameter.
Wed, Apr 1, 2015 at 8:38:52 AM | VG Filtering Walls by Different Base Contraints
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
No, it is just a text parameter that you would need to fill in.
Wed, Apr 1, 2015 at 8:46:01 AM | VG Filtering Walls by Different Base Contraints
revitdeco
Thanks for the help.
Already got it done, works perfectly.
Wed, Apr 1, 2015 at 10:10:50 AM | VG Filtering Walls by Different Base Contraints
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Could you attach an image of how it looks becoming more transparent?  I'm curious to see the outcome.
Wed, Apr 1, 2015 at 10:22:28 AM | VG Filtering Walls by Different Base Contraints
revitdeco
Ya I'm still playing with it to try and get it to where I need it.  I'll share when I get something worthy of sharing.
Schedules - filtering by view or duplicate?
Mon, Jul 28, 2014 at 8:24:36 AM
demo wall schedule "by floor"
Thu, Mar 31, 2005 at 11:16:00 AM
Filter walls by floor level or base constraint??
Sat, Jun 8, 2013 at 9:25:24 PM
filtering selections
Thu, Oct 12, 2006 at 11:52:55 AM
Worksets - Phasing - Phase Filtering Training Videos Now Available
Thu, Feb 23, 2006 at 8:32:50 PM
Page generation time: 0.6516
