21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> cut pattern override view template
I have set up a number of view templates and as a part of those templates I have changed the "cut pattern" override of the structural columns to a dark gray solid fill. so that it can read through the poched walls. everything worked great until yesterday on the latest project. for some reason the dark gray solid fill isnt showing up on some of the structural columns but is on others.
I am attaching some screen shots to better help what I am describing.
Do the columns have the exact same properties?
yes they do. they either are copies or they are from the exact same family
Just to make sure, copy the one on the lower right up and see what happens.
Cut pattern override |
Wed, Dec 4, 2013 at 11:08:45 AM
Revit 2015 Solid Cut Fill Pattern |
Thu, Sep 22, 2016 at 8:27:54 AM
cannot override graphics by category |
Thu, Jan 19, 2017 at 2:46:11 PM
Showing column cut on top of wall cut pattern |
Tue, May 28, 2013 at 4:06:05 AM
Override Phase Filter for Specific View only |
Fri, Nov 4, 2016 at 9:45:40 AM
