Forums >> Revit Systems >> Technical Support >> Level Marks???
Mon, Mar 30, 2015 at 11:14:56 PM | Level Marks???
bigbrother
Is it possible to have 2 or more different level marks in 1 Revit Project file, but, of course, on 2 different views.  I have my default Elevation Datum Marker for my exterior elevations.  I want a different symbol of Level Marker for my interior elevations.  If I change my Level Marker on my interior elevation, my Elevation Datum Marker on my exterior elevation changes too.  How can I make to independent Level Markers?
Tue, Mar 31, 2015 at 7:11:18 AM | Level Marks???
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Click on your elevation>Edit Type>Duplicate and change the Symbol to what you want to use.
Tue, Mar 31, 2015 at 9:53:20 AM | Level Marks???
bigbrother
Sorry, but I did that already and the result is both my Exterior & Interior level marks change to any symbol I choose. Or is there something I'm missing here?
Tue, Mar 31, 2015 at 10:59:07 AM | Level Marks???
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You are still doing something wrong then.  Interior and Exterior do not matter, they both use Levels.  You just need to duplicate the type and change the symbol of one of them.  See my attached images.  If this doens't work you will need to attach some images of your process and problem.
Tue, Mar 31, 2015 at 12:24:33 PM | Level Marks???
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
I think the OP wants to change the symbol of the same level on two different views. In that case, you need to copy the actual level, rename it, change the symbol and use filter tool to show one level or the other.
...or use spot elevation - that would be my choice.
Edited on: Tue, Mar 31, 2015 at 12:25:37 PM
Tue, Mar 31, 2015 at 2:01:47 PM | Level Marks???
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
If that's the case having 2 different levels is not good practice.  Spot elevation would be a better choice.
Wed, Apr 8, 2015 at 11:10:30 AM | teafoe5
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Quoting teafoe5 from 2015-03-31 14:01:47
Not necessarily, especially when working with an addition to the existing building, for example. Having separate levels for an existing building and new addition can be beneficial, even though they are on the same elevation. Let’s say, the client decides to drop down new floor later on in the project. It can be easily done just by lowering a level (associated with the new addition), without disturbing existing elements/building.
Unless you’re specifically referring to the OP’s scenario, where in fact, a spot elevation could be a better choice as I mentioned before.
Wed, Apr 8, 2015 at 12:29:53 PM | Level Marks???
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I'm still going to disagree.  "Let’s say, the client decides to drop down new floor later on in the project" that is basically saying on all additions you should have a new and existing floor level for the same level just in case they move the floor.  I don't see this being practical to do on all jobs.
Wed, Apr 8, 2015 at 2:06:31 PM | Level Marks???
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
I do. The client scenario was just an example. A need for adjusting level elevations could be necessary due to various reasons – architectural design change was just one of them. Keeping existing and new stuff on separate levels proofed to be very useful for me. Just last week, this set up saves me a lot of time after structural engineer’s revisions where I had to adjust new levels while ‘existing’ ones stayed put. ‘Existing’ levels, in my projects, are always pinned and should never be moved, while new ones could be tuned as needed without affecting existing building. You could think of it as having two separate buildings on site – existing and new addition with different set of levels for both, coincidentally with some levels at the same elevation - where linking is not very practical.
Heavy End Tick Marks disappear
Thu, Jul 15, 2010 at 1:55:44 PM
Room tags, floor marks etc. misplaced in the mirrored plan
Wed, Aug 29, 2018 at 2:37:35 PM
Type Marks
Fri, Jun 27, 2014 at 7:14:42 AM
section marks
Tue, May 17, 2005 at 12:54:13 AM
Section marks appearing on plans
Thu, Dec 6, 2012 at 4:26:26 AM
Page generation time: 2.6907
