Forums >> Revit Building >> Technical Support >> Multiple windows in schedule in REVIT 2015
Sun, Mar 29, 2015 at 5:17:01 PM | Multiple windows in schedule in REVIT 2015
MongooseST1
MongooseST1 Avatar
I have 56 casements in my floor plans, visually verified, yet when I do a Window Material takeoff I get 156?....What is going on?
Mon, Mar 30, 2015 at 7:06:46 AM | Multiple windows in schedule in REVIT 2015
mansell5
3.5 Stars: 4 Votes
is it possible you have nested frames together that arent saved as a family, and therefore getting individual counts perhaps?
Mon, Mar 30, 2015 at 7:47:23 AM | Multiple windows in schedule in REVIT 2015
Did you ever 'REVIEW WARNINGS' ?  << You should do this to your files on a regular basis.  You may have multiple items in the same plac.  You should also uncrop your 3D view , pick one of these elements, then right click and select all instaces.  Where are they?
Wed, Apr 1, 2015 at 12:52:57 PM | Multiple windows in schedule in REVIT 2015
MongooseST1
MongooseST1 Avatar
Can you please provide the step by step process of REVIEW WARNINGS?...I have endeavored to follow Adesks HELP on it and it is cryptic at best. P.S. Under The COORDINATION REVIEW dropdown the USE CURRENT PROJECT IS GRAYED OUT
Edited on: Wed, Apr 1, 2015 at 1:07:00 PM
Wed, Apr 1, 2015 at 1:04:59 PM | Multiple windows in schedule in REVIT 2015
What part don't you understand?
Click on the manage tab then warnings in the inquirey column.
You will get several errors with multiple listings that you can expand.
For each error listing, you can use show to locate ... or if you print the file, you can find individual elements by searching by ID number
You can check multiple element checkboxes to perform the available options listed below.  Like if you have multiple instances in the same place, check all but one that are in the same place.
Coordinating window/door schedule with model
Tue, Feb 16, 2016 at 2:13:33 PM
Revit 2015 Dimensioning
Tue, Jul 15, 2014 at 7:44:54 AM
Schedule Help : Adding multiple filter headings under one filter
Thu, Aug 1, 2013 at 12:22:17 PM
Text Scrambling Issue with Revit 2015 LT on Windows 8.1
Sat, Jun 13, 2015 at 11:17:05 AM
Schedule fill in of multiple lines
Fri, Apr 12, 2024 at 6:39:25 PM
13
Page generation time: 7.2835
