Forums >> Revit Building >> Technical Support >> Schedule Calculated Values
Fri, Mar 27, 2015 at 12:05:13 PM | Schedule Calculated Values
AMTroth
I build utility schedules for our projects and am currently trying to filter out equipment that goes in this schedule. We use parameters in the equipment to specifiy water connection size, drain size, gas size ect. I need our plumbing schedule to show all items that have a dimension in any one of these parameters. I tried to use a calculated value parameter in the schedule as a yes/no statement with the following formula
or(Cold Water Size>0", Hot Water Size>0", Direct Drain Size>0", Indirect Drain Size>0", Gas Size>0")
I then filtered my schedule to show only items in which the canculated value comes out yet. However, what ends up showing are only items with a cold water size of greater than 0". None of the other parameters seem to be checked. I have verified that they are all typed correctly including capitalization. I have also tried to put in parenthesis each "paremeter">0".
Nothing seems to work. Is there something wrong with what I have or a better way of doing this? Thanks.
Calculated Values in Room Tags
Wed, Mar 30, 2011 at 4:08:03 PM
Calculated Values
Mon, Mar 20, 2006 at 12:58:54 AM
Schedule totals are not calculated right: 1+1=1 [ 1 2 ]
Tue, Apr 21, 2015 at 1:27:21 PM
17
using schedule keys, shared parameters and calculated values in schematic design
Tue, Mar 6, 2007 at 1:41:36 PM
Calculated Value
Mon, Dec 13, 2010 at 4:46:58 PM
Page generation time: 1.5790
