Forums >> Revit Building >> Technical Support >> Wall opening (door)
Thu, Mar 26, 2015 at 3:24:54 PM | Wall opening (door)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I have a door family I created to just be an opening with trim.  It looks great when its a new door in a new wall but once I do an existing door in an existing wall I get a really dark line one one side.  It looks like the opening lines from the family are coming through but I don't know how to shut them off.  Anyone ever have this problem?
Fri, Mar 27, 2015 at 7:44:21 AM | Wall opening (door)
teafoe,  I looked at this last night and it is strange.  Did you have this same family in 2014?
Fri, Mar 27, 2015 at 9:47:20 AM | Wall opening (door)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
No I made it in 2015.  I can't remember if I modified an existing family or not.
Fri, Mar 27, 2015 at 5:52:35 PM | Wall opening (door)
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
In your family (plan view), dashed symbolic lines are different. One is hidden (cut) and the other is hidden (projection). Make them both the same. Opening object has nothing to do with it – it’s always invisible.
Tue, Mar 31, 2015 at 7:20:44 AM | Wall opening (door)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Wow how did I not see that one???  Thanks a lot
Tue, Mar 31, 2015 at 10:58:12 AM | Wall opening (door)
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Sometimes the most obvious things are causing the most trouble.
You're welcome,
Cheers!
Demo door, make cased opening, no fill in wall
Fri, Mar 23, 2012 at 12:34:24 PM
Door family - opening covers door leaf
Fri, Sep 30, 2016 at 4:36:46 AM
Door / Opening within a Curtain wall.
Thu, Jun 7, 2018 at 5:57:24 AM
door opening cutting parallel wall
Mon, Sep 15, 2008 at 2:54:10 PM
Wall opening setback for door jamb
Tue, Apr 30, 2013 at 8:43:06 AM
Page generation time: 2.3395
