12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> topo contours are offsetting in z direction
I have created a topo-surface from a CAD drawing I got from civil. in the cad drawing the elevation of the contuors check out. when I generate teh topo-surface and place the contour labels they read with an offset of 2'-0". why is this happening and how do I resolve it?
Look at your project survey setting.
You say offset of 2' - what, up/down. Grab your whole surface and move it accordingly. If the site looks right now and will not after you move the site, then your building is not located right.
I think I solved it. I believe I changed the value of the elevation of the survey point whil it was locked and so I changed it back and everything is where it should be
Topo surface Control from imported contours |
Mon, Feb 17, 2014 at 7:28:49 AM
Smoothing contours... |
Tue, Feb 17, 2009 at 8:43:14 AM
Topo contours |
Wed, May 9, 2012 at 8:19:10 AM
Topo map not following CAD Contours |
Mon, Nov 12, 2007 at 8:53:03 AM
Creating Topo using an image |
Mon, Feb 21, 2011 at 2:18:32 PM
