15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Lookup Tables
I'm trying to create a parameter table like the address parameter, where you can have multiple lines of text. I've never played around with these. It would be a simple table that could have infinite lines of text.
I understand they are pulled from .csv files but I am not really sure how to control them or if I even need to do anything special in the csv file since it is just text... Any advice or a good starting place would be appreciated!
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture |
Maybe a lookup table isn't even the correct tool for this... but hopefully you get what I am trying to do. Create a parameter that you can insert text to and when you hit "enter" it creates a new line of text rather than finishes the command.
Lookup Tables again |
Thu, Jul 31, 2014 at 1:45:45 PM
Revit MEP lookup tables / csv files |
Sun, Sep 2, 2007 at 12:27:00 PM
Plumbing fittings are HUGE! |
Fri, Feb 13, 2009 at 6:18:05 PM
Lookup tables - looking up numbers, getting Invalid Input |
Tue, Oct 14, 2014 at 6:49:40 AM
New Help with Lookup Tables on MEP |
Tue, Aug 24, 2010 at 1:51:45 PM
