Forums >> Revit Systems >> Technical Support >> How to make a Detailed Ceiling
Tue, Mar 24, 2015 at 6:56:18 AM | How to make a Detailed Ceiling
gkp7929
2.5 Stars: 2 Votes
Hi,
I need to make a ceiling with hightly detailed  ( same like how we make it on site).
But in revit the ceiling will be shown like some lines in RCP.
I need it properly,Means in a sectional view it should show the entire detailing(distance between ceiling tiles and channels running through the tiles,Ceiling hangers.
I have tried with ceiling based metric profile.I made a void extrusion and add to my project.Then i array it according to my ceiling tiles.It cuts the revit default ceiling and i got the cut profile in section also.But after some time the revit started to crash(some unexpected error occcured).So i guess it was not the proper method to do it.
So,can anyone help me on this?, Is their any method i can make a detailed ceiling?
or is thier any plugin to make such a detailed ceiling?
Thanks in advance
Gibi
Edited on: Tue, Mar 24, 2015 at 6:57:05 AM
Edited on: Tue, Mar 24, 2015 at 6:57:19 AM
Edited on: Tue, Mar 24, 2015 at 6:59:22 AM
Tue, Mar 24, 2015 at 7:28:16 AM | How to make a Detailed Ceiling
You really don't want to do what you ask because over modeling will kill your project performance.  Ceiling hangers, tees etc should all be added as detail elements where you need them.  They can be placed and easily arrayed.
Wed, Mar 25, 2015 at 8:09:30 AM | How to make a Detailed Ceiling
gkp7929
2.5 Stars: 2 Votes
thanks. the purpose of doing detailed ceiling & false flooring is for MEP guys who work on clash detection. if the hooks or hangers are shown in the model then clashes wont be generated.
Wed, Mar 25, 2015 at 8:53:41 AM | How to make a Detailed Ceiling
I don't know anyone that does clash detection with ceiling wire hangers.  I sure don't want to design to that limitation.  The wire locations are best determined in the field.
How detailed do you make your families
Mon, Jan 30, 2006 at 12:03:34 PM
Wall and Ceiling Issues
Tue, Jan 20, 2009 at 7:50:47 PM
Lighting without ceiling
Thu, Sep 10, 2009 at 11:02:50 AM
Ceiling Tag associate to Center of Ceiling instead of Perimeter.
Mon, Feb 8, 2016 at 12:46:31 PM
Detailed section elements
Tue, Mar 16, 2010 at 3:13:53 PM
Page generation time: 0.5247
