Forums >> Community >> Newbies >> Phasing a Linked File
Sun, Mar 22, 2015 at 8:55:10 AM | Phasing a Linked File
coastalclimbing
 I have an old file that I created that is shows the existing plan for a building. I was not aware of the phasing option in revit so I did a save as to create a new file showing proposed renovations. Now I have found this amazing phase tool revit has provided us with and I would like to use it.  Is there a way to link or import the older existing phase file into the proposed file and quickly transfer that file so that I can use phasing into the new file or will I have to redraw the entire existing building?
Sun, Mar 22, 2015 at 9:33:45 AM | Phasing a Linked File
If the elements exist in your file, simply select them and change their phase.
Thu, Mar 26, 2015 at 11:40:52 AM | Phasing a Linked File
coastalclimbing
I understand how phasing works but I am curious if I can use phasing on a linked revit file? I would rather not have to redraw this entire house.
Thu, Mar 26, 2015 at 11:55:21 AM | Phasing a Linked File
First - did you try?
Second - What do you need a phase for with a linked file.  You can over-ride the entire file's graphic to meet your phase requirements very easily.
I would doubt that you would want to link a file that you may need to alter.  What happens when you need to put a door in that existing wall to get into your new area?  CAN'T!  So you open the link, cut the hole - but which file has the door?  You asked "...or import the older existing phase file into the proposed file..." and that is what I would do.  Actually, I might even start with that file, change everythin to existing as I said then add the new.
Phasing a linked cad item - v14
Tue, Aug 4, 2015 at 2:01:01 PM
Can the linked revit drawings preserved its phasing setting in master site plan?
Fri, Apr 4, 2008 at 8:58:29 PM
Linked Revit Topography file displayed in hidden lines in 3d view main bld file
Sat, Jul 7, 2012 at 3:38:16 PM
Linked File, how can I dimension it?
Sun, Dec 19, 2010 at 8:08:50 PM
Scheduling from linked Revit file
Tue, Mar 27, 2012 at 7:39:28 AM
Page generation time: 0.4867
