Forums >> Revit Structure >> Technical Support >> Grid Lines at Face of Steel, Not Centerline
Thu, Mar 19, 2015 at 3:03:44 PM | Grid Lines at Face of Steel, Not Centerline
maxness
Is there a way to attached columns to a grid utilizing a face of steel rather than the centerline.  For example, a pre-engineered metal building foundation layout will utilize an Edge of Concrete or Face of steel at a sidewall where the grid line is parallel to the column flange.  The grid line as a centerline makes sense in the other direction where the grid line is parallel to the web.
The reason I ask, is it's cumbersome to lock footing, columns, piers, walls to a grid manually.  If you can place a column "at grids" revit will do the locking for you.....then you can place footings and piers "at grids/columns" as well.
Does this make sense?  Column centerlines are only utilized in both directions as infield or interior columns.  The endwalls and sidewalls must utilize Face of Steel dimensioning.
Anyone help me out?
Thanks.
Thu, Mar 19, 2015 at 3:16:30 PM | Grid Lines at Face of Steel, Not Centerline
maxness
Should have said, I'm a SE with Revit 2014 and earlier.
Grid line as centerline?
Mon, Jan 19, 2009 at 9:47:23 PM
How to create a steel grid
Thu, Feb 25, 2010 at 5:21:40 AM
Regular grid on Curtain system by face
Mon, Sep 30, 2013 at 2:57:17 PM
Changing distance btwn grid lines with walls....
Thu, Oct 27, 2011 at 7:08:19 AM
Set an interior wall's centerline distance from the exterior face of building?
Sun, Jan 16, 2011 at 12:55:47 PM
Page generation time: 0.6844
