14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Text Box Width Factor Masking Error
0 Posts No Rating |
I'm working with a text that has a width factor of 0.80. The text appears correctly in the model, but when printed, the opaque background of the text masks the area as if there was a width factor of 1.0, therefore masking more than it needs to, which includes parts of the model. Is there a way to change the width factor of the masking area as well? This appears to be a revit glitch.
The text masking area has always been a little strange.... sorry - I have not ever heard of a way to change this.
2 Posts No Rating |
I was curious so I tested some things- could it be your printer? Are you printing to PDF? I would check your settings- raster or vector processing, quality, etc.
I tested with .8 and 1.0 width factors, and both printed- to PDF and directly to my printer.
Granted, I'm using fully updated 2014 and you don't state your version.
0 Posts No Rating |
Sorry, I forgot to mention I am using 2015. I played around some more with print settings - when i print to PDF it works, but when i export DWFs it does not. Of course, DWF is what i need. Even changing the width factor back to 1.0 does not seem to help - see attached image (the top text box is width factor 0.8, the bottom is 1.0) - the masking area seems to be somewhere in between.
Any ideas on how to fix the DWF export setting to deal with this issue?
I suggest you send the issue to autodesk.... It may be a known issue but if it is not, then maybe they will put it on their to do list......
Model Text Width Factor?? |
Tue, Feb 17, 2009 at 2:10:48 PM
Can you adjust the text width for dimensions? |
Thu, Oct 27, 2005 at 5:20:00 PM
text width factor for dimensions |
Thu, Apr 20, 2006 at 7:44:21 AM
Width factor as a parameter |
Thu, Oct 30, 2014 at 7:23:29 AM
Masking Regions in Symbols not working |
Thu, May 7, 2009 at 5:47:00 PM
