Forums >> Revit Systems >> Technical Support >> Navisworks Question
Wed, Mar 18, 2015 at 10:10:55 AM | Navisworks Question
SKJWW
Sorry if this is the wrong place to post this, this is my first post here.
I was trying to export a revit file to an NWC for a client but due to our Navisworks 2015 not being able to be properly deployed I cannot just use the "export" button in Revit 2015.
I tried to just detach a model from central and then open it directly into navisworks using apphend but I keep getting that the model is corrupt. So my other solution was to export an FBX file from Revit and then open that FBX model in Navisworks and then export the FBX as an NWC from there.
I guess my question is is there a difference between an FBX to Navisworks and a Revit model to Navisworks?
Or will the same information be conveyed?
Thu, Mar 26, 2015 at 7:45:28 PM | Navisworks Question
koolair
4.5 Stars: 2 Votes
You could export a dwf and append that to your main model.
Tue, Apr 28, 2015 at 1:17:16 PM | Navisworks Question
Pikachu123
If you go to your control panel>clcik programs> programs and features> then right click the version of Navis you are working in & click "Unistal/change" >then click the "add or remove features" button> and select the program you want the exporter feature to interact with (probably the version of revit you are using). Hope it helps.
Casper the Friendly Ghost Add-in NavisWorks 2016
Mon, Apr 25, 2016 at 5:01:17 PM
2016 export Revit files to Navisworks without using Navisworks Exporter.
Thu, Apr 21, 2016 at 4:53:15 PM
Revit - ADT in NavisWorks
Mon, Mar 16, 2009 at 2:20:20 PM
Revit to Navisworks
Wed, Jul 5, 2006 at 4:25:35 PM
NavisWorks Exporter
Mon, Mar 28, 2011 at 3:40:00 PM
Page generation time: 1.3848
