Forums >> Revit Building >> Technical Support >> annotation family with lines on top of a filled region
Sat, Mar 14, 2015 at 10:32:48 PM | annotation family with lines on top of a filled region
glenlake
3.5 Stars: 3 Votes
Hi all!
I have to create an opaque annotation family with lines and text on top of the filled region (it should cover elements below it in the project). (Revit 2014).
I create a generic annotation family with lines which I need. Then I import there another family which consist only of a filled region. It covers my lines in the family, but the lines are on top of the region after I load the family in the project.
Is it possible to make it in not so strange way, but in one family (a symbol, generic annotations or anything else)?
Thank you.
Wed, Mar 25, 2015 at 6:20:35 AM | annotation family with lines on top of a filled region
Shatner86
Shatner86 Avatar
5 Stars: 2 Votes
hi Glenlake,
Why do you need this filled region? Is this to only keep the text readable?
If so, on your label "edit Type" you can give the label a border and set the 'Background' from Transparent to Opaque.
Kind Regards,
Shatner86
"Try not to become a man of success, but rather to become a man of value"
-Albert Einstein
Wed, Mar 25, 2015 at 6:29:23 PM | annotation family with lines on top of a filled region
glenlake
3.5 Stars: 3 Votes
Thank you for the reply.
I actually use both text kinds - opaque and transparent.
This Filled region i need to show in this detail hatches representing different textures.
I tried a detail item -- and ilines, after the family is loaded in the project, appear below the filled region.
Why is it so?
 Thank you again.
Visibility of Filled Region Boundaries over walls
Wed, May 24, 2017 at 1:54:59 PM
Filled Region in a family
Mon, Jan 13, 2014 at 10:34:31 PM
Door Display Issue & Annotation Filled Region Not Printing
Thu, Jul 12, 2007 at 9:55:56 AM
WHY WILL SOLID BLACK "ANNOTATION FILLED REGION" NOT PRINT!
Sun, Aug 3, 2008 at 1:51:22 PM
Filled Region <invisible lines> overlapping and hiding surrounding lines
Mon, Feb 4, 2008 at 10:41:34 AM
Page generation time: 0.9975
