Forums >> General Discussion >> Wishlist >> Doors
Thu, Jul 1, 2004 at 8:44:18 AM | Doors
SteveB
3.5 Stars: 5 Votes
I wish door schedules would report 2 additional characteristics: The thickness of the wall they are installed in and the handing of the door, both seem possible.
Fri, Sep 17, 2004 at 9:41:24 AM | RE: Doors
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
you should be able to add an instance parameter to the doors to schedule the door handing... I think it would be nice if you could automatically number the doors based on the room that it's opening into as well... Post edited on 2004-09-17 09:41:39
Hiroshi Jacobs
The Catholic University of America
Thu, Jul 26, 2007 at 7:03:46 AM | Doors
rosemaryW
Did you ever get anywhere with doors knowing how thick the walls they are in were?
Thu, Jul 26, 2007 at 9:16:27 AM | Doors
broncos4life
3.5 Stars: 11 Votes
Is that no the throat size of a door frame?
Thu, Jul 26, 2007 at 10:15:29 AM | Doors
rosemaryW
Thu, Jul 26, 2007 at 10:18:01 AM | Doors
rosemaryW
OOps! My last reply didn't work...
Throat size? What is that and how can I get it to show on a door schedule? Door you have door families that do this?
Thu, Jul 26, 2007 at 2:18:35 PM | Doors
broncos4life
3.5 Stars: 11 Votes
Here is a door that we used to use that has the Throat size calculated.  I can't figure out where some of the parameters are comming from though.  I will take a deeper look at it later.
Fri, Jul 27, 2007 at 8:07:26 AM | Doors
The door that broncos4life posted does not work and does not give the wall thickness.  The throad it uses is a parameter calculated from another parameter that is set, not read.
Tue, Sep 4, 2007 at 4:35:46 AM | Doors
Kytom
No solution?
Tom
Fri, Mar 24, 2017 at 10:37:28 AM | Doors
archigrafix
5 Stars: 4 Votes
For door handing see Xdoor here:
https://apps.autodesk.com/RVT/en/Detail/Index?id=2481590927896495348&appLang=en&os=Win64
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Tue, Jul 11, 2017 at 9:12:28 AM | Doors
LDDownes
Wondering if anyone knows where to get a bifolding closet door... been looking for a while and can't seem to find one. I'm looking for single and double, I attached some pics as well. Thanks!
Tue, Jul 11, 2017 at 9:14:43 AM | Doors
These doors are in the Revit library.
Anyone have pocket doors or pivot doors?
Tue, Jun 25, 2019 at 12:37:56 PM
dOORS AND DOOR SCHEDULES
Mon, Aug 6, 2007 at 11:28:15 AM
Curtain wall doors wont center up
Mon, Oct 12, 2009 at 4:28:48 PM
doors opened in 3D views
Wed, Sep 27, 2006 at 9:20:29 AM
Doors not appearing in door schedule... Help
Thu, May 30, 2013 at 11:58:43 PM
Page generation time: 2.7736
