Forums >> Revit Building >> Technical Support >> How do we retain visibility graphics settings for our consultant files?
Thu, Mar 12, 2015 at 1:58:53 PM | How do we retain visibility graphics settings for our consultant files?
Cmadden1
We're using Revit Architecture 2014.  How do we retain visibility graphics settings for our consultant files? Everytime our consultants update their Revit models and we reload them, we have to go through every view and reset the "revit link display settings".  It is beyond time consuming.  Is there a way to set a template or filter to retain our display settings when we get our updated consultant models?
Thanks.
Thu, Mar 12, 2015 at 2:04:42 PM | How do we retain visibility graphics settings for our consultant files?
I don't understand what you are doing.  Are you rloading or are you deleting and re-linking.  All of your VG strring should remain except possibly fo hidden individual elements.
Please explain the process you are using.
Thu, Mar 12, 2015 at 2:12:16 PM | How do we retain visibility graphics settings for our consultant files?
Cmadden1
Our PM is doing it, not me.  I believe he's deleting and relinking.  How SHOULD we be updating our consultant files?
Thu, Mar 12, 2015 at 2:18:49 PM | How do we retain visibility graphics settings for our consultant files?
Use the reload from function in the manage links area.... The file name can change and that doesn't matter, even the path can change.
I always recommend that the linked file be placed in the same directory or sub-directory of where your Revit file is.  We save the new linked file with basically the same name except we always add the date to the name so it is easy to see if you have the latest loaded.
Retain visibility if the linked dwg's are updated outside REVIT
Fri, Nov 9, 2007 at 10:14:52 AM
Visibility Graphics settings: saving them when unloading a linked model
Fri, Feb 25, 2011 at 1:54:00 PM
Elements not showing properly from linked model
Thu, Mar 10, 2016 at 7:43:30 AM
Wall and interior elevation visibility graphics settings.... [ 1 2 ]
Thu, Aug 2, 2007 at 9:29:35 AM
15
Locking Visibility Settings
Fri, Sep 30, 2005 at 10:00:22 AM
Page generation time: 0.4266
