26 Users Online (24 Members):
Forums >> Revit Structure >> Technical Support >> original title section changes when duplicated view is created on a new sheet -
i have a project with all my floor plan already in sheets (24x36), lets say floor 1 on sheet 101 floor 2 on sheet 102 etc… i have also section 1 and 2 that cuts all the floors so it appears on each floor sheet, but the section is called on sheet 200. I had to do a revision of a little part of all the floor on a smaller sheet (8x11) so I duplicated (dependent) view of each floor that a call on sheet (8x11) that I call CR01, CR02 etc… since my section 1 and 2 also appears in those new duplicated view, and are called in new sheet CR01, CR02, the section title in the original sheet 200 ( 1/200 and 2/200) change automaticly to 1/CR01 and 2/CR02, how can it stay 1/200 and 2/200
how to avoid it..
I can't follow your question - too confusing.
I think you need a better understanding of dependent views.
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-EF8CCDA0-9946-49FA-B7AB-2B94470525D2
I believe this thread will point you in the direction you need to take: (There is no need to do an overlay)
http://www.revitcity.com/forums.php?action=viewthread&thread_id=24249
i'll try again,,,,
i have a floor plan with all my detail and annotations showed on it. (pdf 1)
i have multiple section on it too, and particully 2, the 1/S202 and 2/S202 the are displayed on sheet S202 (pdf 2)
i had to do an instruction on a smaller sheet so i duplicated my floor plan (dependent) and crop it a little (pdf 3)
i put that dependent new view on a smaller sheet which is call INS-09_CR-01 (pdf 4)
since tha, now those 2 sections that where displayed on S202, are not named 1/S202 and 2/S202 anymore they changed to 1/INS-09_CR-01 and 2/INS-09_CR-01...
how can i let be named as they were before... ???
This is because you are using dependent views!
Please read the thread I posted. You are doing this so you can create a small sheet for Revisions ... correct. I outline a much easier and better process then using dependent views. << They are a nightmare for this.... PLEASE READ THE OTHER THREAD and try it out. We have been using that process for nearly 8 years and it works great!
I had forgotten that Revit changed in 2013 and the overlay titleblock family in that AUGI thread I point to no longer works. The problem is in the nested filled rgion. I am adding a new response in this thread that has an edited family that does work. I removed the original family name but I don't take any credit for developing this process.
Viewport title for sections |
Thu, Mar 22, 2007 at 10:04:17 AM
Section line disappears from plan when section view is placed on same sheet |
Thu, Sep 4, 2014 at 7:46:20 AM
Section Title View deleted can not recover |
Tue, Jun 9, 2015 at 7:48:40 AM
View Title - Alignment/Snap on sheet [ 1 2 ] |
Thu, Jan 25, 2018 at 7:56:01 AM
16
How to link a Revision Schedule on Title sheet with Title Block |
Fri, Jan 11, 2013 at 7:26:26 AM
