Forums >> Revit Building >> Technical Support >> Options not working
Wed, Mar 11, 2015 at 8:11:57 AM | Options not working
aecat
Hi,
I am having a problem with Revit 2015. When I click on the big R, and try to access the options button, I receive the following error message - "a required resource was unavailable."
I can't access the options to customize anything. Does anyone know a solution to this problem?
Thanks.
Wed, Mar 11, 2015 at 8:17:45 AM | Options not working
Maybe you have a bad install.... I have not seen this complaint here before.
You can go to the Autodesk site and ask your question there and you might also check with your re-seller.
see all design options in one view?
Tue, Aug 28, 2007 at 4:20:36 PM
Design options - Working with the design options
Tue, Nov 1, 2016 at 12:26:15 PM
Design Options doesn't seem to be working properly. Help
Mon, Aug 12, 2013 at 10:35:21 AM
Design options and topography
Thu, Dec 2, 2010 at 12:56:10 PM
design options
Wed, Jan 11, 2012 at 7:17:57 AM
Page generation time: 0.3259
